mik60ish Posted April 6, 2005 Report Share Posted April 6, 2005 I need the tool or tools to adjust the rear paoli shock on my SY175 what alternatives will fit, will I be able to get one from a wreckers, from an alternative bike? Quote Link to comment Share on other sites More sharing options...
dgshannon Posted April 7, 2005 Report Share Posted April 7, 2005 A tool is the proper way, but is not necessary. A large diameter punch, with a flat end, is all you need. Place it against the lower ring, and tap it loose with a hammer. Use the same to spin the rings around to the desired position, and then snug the bottom ring up tight against the second ring, to lock it down. Quote Link to comment Share on other sites More sharing options...
mik60ish Posted April 7, 2005 Author Report Share Posted April 7, 2005 DG that simple hey! thanks for that Mike Quote Link to comment Share on other sites More sharing options...
dgshannon Posted April 8, 2005 Report Share Posted April 8, 2005 Just that simple. Be sure to re-jet your carb and do the exhaust modification as well. These will make a major difference in the performance of the bike. Quote Link to comment Share on other sites More sharing options...
mik60ish Posted April 9, 2005 Author Report Share Posted April 9, 2005 DG Yeah went out this afternoon got soaked right right through practicing, go out with my son whom we both bought the 175's at the same time and my grandson 6 years old QR50, grandaugther 10 with a Z50 (BLISS) Just getting going then the rain came down have done the main jet 17.5 I knocked out 2 baffles my son knocked them all out, mine is still a bit fluffy. So will have to knock the other 2 out, my son has gone for smaller sprocket on the front he likes it as he can use 1st & 2nd I will leave mine as I do most sections in 1st anyway. But the best mod so far is a slow action throttle much more control as the clutch is a bit fierce as was sent with cable clutch with the maguire hydraulic to follow when the have got it right. Quote Link to comment Share on other sites More sharing options...
dgshannon Posted April 9, 2005 Report Share Posted April 9, 2005 I am glad you mentioned the slow throttle, as I have been considering doing the same. I have alway run slow throttles on my bikes, but did not immediatly consider it as a need on the 175. But, the way the power comes off idle (slow rpm) is pretty snappy. Combine that with the clutch, and it does make things a bit jerky. Mine has the hydraulic clutch, but is not as smooth as I would like. Magura has a new batch available that has undergone a bit of redesign to make them work better on the SY175F. I have one on the way, and am anxious to give it a try when it arrives. If I can get the clutch action sorted out, then I think it will be a great bike. I love all of it's other characteristics. Quote Link to comment Share on other sites More sharing options...
mik60ish Posted April 10, 2005 Author Report Share Posted April 10, 2005 the slow action throttle has transformed the bike, such a simple mod Domino just a straight swap! So you haven't tried the clutch plates from BJ Racing as he's in your kneck of the woods. So you don't mind spending out on another Magura hydraulic clutch when are they due, perhaps thats the ones we are supposed to be getting? Quote Link to comment Share on other sites More sharing options...
