Unwell gasser
theboo
Rode a couple of trials over xmas, one went fine the other was over almost before it started rode a couple of sections and revs stuck on t around mid point, stopped the bike ran it a bit again and the same thing again, throttle fine,with a touch of play, stripped carb the pilot jet was almost solid,not dirt though ?? ,put it back together, i did nick the fuel pipe so had to cut a bit off, popped a new plug in and the bike kicked first time but failed to tick over without a touch of throttle,i did an oil change a couple of weeks ago ,and ive noticed its coloured up a little already any idea,s, someone suggested crank seals,or an air leak ???
