canada280i Posted January 10, 2012 Report Share Posted January 10, 2012 I was skeptical as well at first but thought I would try a set. I had the boyesens in and back out for comparison and had to put them back in again, cleaner quicker throttle response, smoother reving all the way through. Engine response was much smoother with them in than the standard single petal reeds, best $40 I ever spent. You can find the number on the boyesen website at this direct link: http://boyesen.com/vaf/product/list/?category=%3F&make=21&model=205&option=205&year=626 , you can also probably get someone local to match a set and provide. Quote Link to comment Share on other sites More sharing options...
nelly1 Posted January 10, 2012 Report Share Posted January 10, 2012 thanks very much mate im going to try them Quote Link to comment Share on other sites More sharing options...
canada280i Posted January 11, 2012 Report Share Posted January 11, 2012 Motomerlin in the UK have them in stock at this link: http://www.motomerlin.org.uk/product/Boyesen_Reeds_for_Montesa_315_trials_boymo Quote Link to comment Share on other sites More sharing options...
sharkbait Posted January 11, 2012 Author Report Share Posted January 11, 2012 Little update. New piston arrived from Feetup this morning (great service). Fitted it this afternoon (as our electricity was off for maintenance) and the result is that it's much better. There is still a bit of a rattle so I now need to decide if I can live with this or send the barrel for replating which will cost Quote Link to comment Share on other sites More sharing options...
nelly1 Posted January 11, 2012 Report Share Posted January 11, 2012 wouldnt the rattle be the small end rather than anything else Quote Link to comment Share on other sites More sharing options...
canada280i Posted January 11, 2012 Report Share Posted January 11, 2012 I would do the bearing and pin before replating the barrel. Quote Link to comment Share on other sites More sharing options...
sharkbait Posted January 11, 2012 Author Report Share Posted January 11, 2012 I would do the bearing and pin before replating the barrel. I think your both right. Will fit new ones. I'll b a dab hand at stripping these things by the time I'm done Quote Link to comment Share on other sites More sharing options...
nelly1 Posted January 11, 2012 Report Share Posted January 11, 2012 good il fetch mine to you Quote Link to comment Share on other sites More sharing options...
sharkbait Posted January 12, 2012 Author Report Share Posted January 12, 2012 good il fetch mine to you No worries Trickiest bit is squeezing the rings together while putting the barrel back on. Seems you need three hands! Quote Link to comment Share on other sites More sharing options...
nelly1 Posted January 13, 2012 Report Share Posted January 13, 2012 im doing my top end next month just new rings bearing and pin i have noticed a slight rattle from time to time plus i want to do it need to fit those reeds before i do the top end so i can notice the difference Quote Link to comment Share on other sites More sharing options...
