gwhy Posted February 28, 2012 Report Share Posted February 28, 2012 there isnt a 'one fix all' solution to this problem , when I first started to play around with throttle control/resolution I fitted a toggle switch that allowed 2 resolution settings. In one position the throttle resolution is halved and this allowed very good slow control but this would mean that the switch needed to be switched to allow full speed ( normal resolution ) this was not to bad once you got used to it, it was like the equivalent of having a 2 speed gear box but without a clutch, it got very intresting if you forgot to shut the throttle off before you switched into normal resolution Quote Link to comment Share on other sites More sharing options...
jonnybmac Posted February 28, 2012 Report Share Posted February 28, 2012 can you not create a mod to make the rear brake lever into a switch so that when you pull its at slow speed and when out its at normal speed? then fabricate a rear brake where the footpegs are Quote Link to comment Share on other sites More sharing options...
gwhy Posted February 28, 2012 Report Share Posted February 28, 2012 On 2/28/2012 at 8:20 PM, jonnybmac said: can you not create a mod to make the rear brake lever into a switch so that when you pull its at slow speed and when out its at normal speed? then fabricate a rear brake where the footpegs are I have been thinking about having the rear brake lever linked into the throttle , but instead of just a switch on the lever it will be continually adjustable dependant on position so it will behave like a clutch, it would work but I will have to try it to see if it is worth while.The main problem would be sorting out a brake lever that will act in the same way as a throttle. You can get e-brake levers and these already have a on/off switch built in and are widely available it would be very easy to setup but like you say a foot brake would have to be sorted out on the osets, but for my application I already have a rear foot brake so it will be just a matter of figuring out the handlebar lever. Quote Link to comment Share on other sites More sharing options...
sparkalounger Posted March 2, 2012 Report Share Posted March 2, 2012 gwhy, do you have a pic up of your bike wit the rear brake installed? I would love to see how you did it! Quote Link to comment Share on other sites More sharing options...
gwhy Posted March 2, 2012 Report Share Posted March 2, 2012 Hi Spark, If you are revering to the rear foot brake then I have just a standard sherco ( not a moddified oset ) e-brake levers with built in on/off switches are like these ones Quote Link to comment Share on other sites More sharing options...
sparkalounger Posted March 6, 2012 Report Share Posted March 6, 2012 thanks. yeah, i was wondering about the foot brake. I ride a sherco so i will take a look at mine to get an idea of how it could work. Quote Link to comment Share on other sites More sharing options...
gwhy Posted March 13, 2012 Report Share Posted March 13, 2012 I may have a very cheap/easy/adjustable solution to the snatcy hall throttle problem, I just need to get out on the bike and test it, unless anyone else wants to. it involves soldering a trim pot into the 0v of the throttle . This is not my solution, I found it on another forum but just may fix the problem. use a 10 turn 1k trimmer pot in series with the ground wire going to the throttle. cut the black wire and connected the ends to the resistor. Be sure to put the wheel off the ground when you first turn on the controller as the motor might start running. With the controller on, you adjust the trimmer pot until the motor starts to move, then back off until it just stops. It's a good idea to back it off a tiny bit more just so variations in temperature don't cause the motor to start creeping at stop. Quote Link to comment Share on other sites More sharing options...
dave horne Posted August 2, 2012 Report Share Posted August 2, 2012 A multi setting 'plug in' Pico Amps controller is now available from OSET. My son has been using one over the last couple of months, transforming the power delivery of the 36v bike. Quote Link to comment Share on other sites More sharing options...
huskyal Posted August 3, 2012 Report Share Posted August 3, 2012 On 8/2/2012 at 9:31 PM, dave horne said: A multi setting 'plug in' Pico Amps controller is now available from OSET. My son has been using one over the last couple of months, transforming the power delivery of the 36v bike. Thats good to know, I couldn't see them on the UK OSET website. I have recently fitted a kelly controller which completely fixes the problem but a plug in option would have saved a lot of messing around. Quote Link to comment Share on other sites More sharing options...
redondo76 Posted July 31, 2013 Report Share Posted July 31, 2013 Hello, Thread stopped in 2012? Is there a plug-in Pico Amps Controller avaialble or not? Quote Link to comment Share on other sites More sharing options...
gwhy Posted April 26, 2014 Report Share Posted April 26, 2014 (edited) throttle tamers are $45 delivered international and $40 delivered stateside, I now have the contact details of the seller if anyone would like the contact details then please PM me. The throttle tamers allow adjustment of throttle resolution and up ramp speed and a includes a glitch filter. Edit: The throttle tamers are not my product and I don't sell them. Edited April 26, 2014 by gwhy Quote Link to comment Share on other sites More sharing options...
