bri8617 Posted April 7, 2005 Report Share Posted April 7, 2005 took the chain off my sherco 200 due to it being fully adjusted up and chain stiil a bit loose.had a link taken out of chain now the chain is adjusted to number 2 on cams but seems a bit too tight.theres about 10-15 mm of up and down play on chain .is this correct???? Quote Link to comment Share on other sites More sharing options...
bri8617 Posted April 7, 2005 Author Report Share Posted April 7, 2005 thanks for that might be easier to buy a new chain.only had the bike a couple of months don,t know when it was last changed Quote Link to comment Share on other sites More sharing options...
bri8617 Posted April 7, 2005 Author Report Share Posted April 7, 2005 will have to sort it out .looks like new chain and sprockets to be on the safe side.thanks for your help Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted April 7, 2005 Report Share Posted April 7, 2005 Grab the chain at 3 o'clock on the rear sprocket and pull towards the back of the bike. If you expose half a tooth or more, you need a chain. When adjusted correctly, the top of the chain tensioner should be about 1-1.25" from the bottom of the swingarm Quote Link to comment Share on other sites More sharing options...
