inchhigh Posted January 21, 2012 Report Share Posted January 21, 2012 Hi all,I have a 2010 300 4t i am having problems with the clutch.the problem is when the engine is cold the clutch doesn't work ie put it in gear and its away on its own.Now I've had the gear return spring snap which i think is caused by this problem.The clutch mod has been done by a previous owne.can anyone help pleaser Quote Link to comment Share on other sites More sharing options...
02-apr Posted January 21, 2012 Report Share Posted January 21, 2012 (edited) Hi all,I have a 2010 300 4t i am having problems with the clutch.the problem is when the engine is cold the clutch doesn't work ie put it in gear and its away on its own.Now I've had the gear return spring snap which i think is caused by this problem.The clutch mod has been done by a previous owne.can anyone help pleaser This is another one of those "They all do that Sir" problems. I assume that, like my Beta, the clutch clears eventually. The way to speed this up is to push the bike off with a foot as you put it in to gear with the clutch lever in then change up the box, holding the lever in all the time; when you get to fourth the clutch will free and you should be OK after that. Or use the bike every week. Edited January 21, 2012 by 2/4 Quote Link to comment Share on other sites More sharing options...
helloyes Posted January 21, 2012 Report Share Posted January 21, 2012 mine did that !! i changed the oil to mobil 1 15/50 motorcycle oil, was fine once that was done allways warmed the bike up before i rode it, good luck Quote Link to comment Share on other sites More sharing options...
paul w Posted January 21, 2012 Report Share Posted January 21, 2012 change oil brand, to one for 4t mx engines. before re filling with new oil remove the clutch plates and clean all the old oil off. lastly when you finish riding pull the clutch lever in and hold it back with an elastic band, do this while the engine is hot. following week no sticking problems. Quote Link to comment Share on other sites More sharing options...
schmorgas Posted January 21, 2012 Report Share Posted January 21, 2012 That old chestnut! Yes, both my Rev 4t and now my '11 Evo 4t have done it. But only when cold. Get the thing properly warmed through before selecting gear and it's fine. Quote Link to comment Share on other sites More sharing options...
nzralphy Posted January 21, 2012 Report Share Posted January 21, 2012 just do the clutch mod pinned to top of the Beta forum. It fixes it. Done Quote Link to comment Share on other sites More sharing options...
02-apr Posted January 21, 2012 Report Share Posted January 21, 2012 just do the clutch mod pinned to top of the Beta forum. It fixes it. Done It does but not if you leave the bike for weeks and weeks between uses. Quote Link to comment Share on other sites More sharing options...
inchhigh Posted January 23, 2012 Author Report Share Posted January 23, 2012 well think i've got it sorted.had to wait a while for the selector spring to come.all the clutch plates were stuck together i washed them and it looked like a greasy film on them is this from the oil? Quote Link to comment Share on other sites More sharing options...
