Uncle Charlie Tech Tip #486
I read somewhere that you need to be careful when doing this as the oil can get drawn through into the carb which causes all sorts of silly problems.
A good idea though, I do it, just do not use too much!
Only problem with this one is that the airbox on most trials bikes is on the wrong side of the filter. i.e. the filter fits on to the neck of the carb.
Not on gas gas pro's :D I cant help but get oil all over the inside of the air box trying to do the poxy fiddley job of screwing the air filter on :D
