mattc Posted January 25, 2012 Report Share Posted January 25, 2012 Hello everyone, I'm new to this so be gentle. Just having a few issues with the clutch on my 2003 250 pro and wondered if someone on here could answer a question. On taking the clutch apart I noticed the steel plates struggle to slide up and down on the location poles and the poles have scoring on them. Do I clean the poles with emery and file the cut outs on the steel plate so they slide better, or do I need to buy all new? Cheers Matt. Quote Link to comment Share on other sites More sharing options...
jse Posted January 25, 2012 Report Share Posted January 25, 2012 Hello everyone, I'm new to this so be gentle. Just having a few issues with the clutch on my 2003 250 pro and wondered if someone on here could answer a question. On taking the clutch apart I noticed the steel plates struggle to slide up and down on the location poles and the poles have scoring on them. Do I clean the poles with emery and file the cut outs on the steel plate so they slide better, or do I need to buy all new? Cheers Matt. You could dress the surfaces with fine emery. The tabs on the fibers only move a small amount. If you took too much from the surfaces it could lead to accelerated wear due to excessive movement of the tabs within the "finger" posts. Jon Quote Link to comment Share on other sites More sharing options...
