Bultaco Ignition In Degrees Btdc
tonyp
Hi,
I've recently got a Bultaco 198A. I believe the ignition timing is between 2.8mm and 3.0mm BTDC.
I haven't yet got a TDC Tool, but I guess I'll need one.
- are the standard tools OK, or do I really need a micrometer version ?
But I was wondering...
- what's this measurement in terms of degrees BTDC ?
- I can't imagine being able to measure 2.8mm to 3mm with any great accuracy, so isn't it easier/better to measure in degrees ?
Tony P
  On 1/25/2012 at 11:07 PM, tonyp said:
Hi,
Tony P
No, if you do not have the good tool to begin with, you will never align a degree wheel. A vernier type works, dut a dial indicator is better! :thumbup:
  • 3 weeks later...
