bsw Posted January 26, 2012 Report Share Posted January 26, 2012 Hi Just broke part of the inner clutch holder/basket whilst trying to remove it to change crank seal.Will one of a DT fit? Quote Link to comment Share on other sites More sharing options...
tony27 Posted January 27, 2012 Report Share Posted January 27, 2012 Compare part numbers on www.csmnl.com to get an idea, would think that quite a few parts would interchange between dt's & ty's Quote Link to comment Share on other sites More sharing options...
mattylad Posted January 27, 2012 Report Share Posted January 27, 2012 You also need to check if there are the same number of teeth as the primary drive ratio may be different. There seem to be quite a few on the bay How did you break the inner, its normally the outside that breaks Quote Link to comment Share on other sites More sharing options...
bsw Posted January 27, 2012 Author Report Share Posted January 27, 2012 How did I break it well, lets say I did not put much thought in removing it and used the inner bolts to lock it rather than wait to get the proper tool. Quote Link to comment Share on other sites More sharing options...
ausy300pro Posted January 28, 2012 Report Share Posted January 28, 2012 no it is not same as a dt for a start it is a deeper basket and may also have different gear, I waited months (perhaps more than a year) to locate a new TY 175 clutch basket as mine had wear, I never came across a basket from any other model that would fit. a DT complete clutch may do with a DT casing as that also sticks out a little further than the TY one. Quote Link to comment Share on other sites More sharing options...
bsw Posted January 29, 2012 Author Report Share Posted January 29, 2012 thanks for the info ,now i have to find the correct component. Quote Link to comment Share on other sites More sharing options...
pheonix_tat Posted February 1, 2012 Report Share Posted February 1, 2012 thanks for the info ,now i have to find the correct component. I did exactly the same and got a replacement from RD Motorcycles for Quote Link to comment Share on other sites More sharing options...
ausy300pro Posted February 1, 2012 Report Share Posted February 1, 2012 sorry may have given a bit of duff info, looks like there may be some years of DT175 that are same but some are not, I bought a DT and it was wrong, I am 99% sure a TY suitable item will have part number beginning with 525- Quote Link to comment Share on other sites More sharing options...
