New 315 Owner
bababoom
Evening all just bought myself a 315 needs a bit of work but the engine sounds and runs fine and it was cheap enough.
First couple of questions, the chap i bought it from said it was a 98/99 model how do i tell for sure what the year is?
Also how much oil does the gear box hold?
think that's enough for now :thumbup:
  On 1/28/2012 at 8:08 PM, furse said:
what make are the forks it Showa or Pioli?
is the rear brake caliper ontop of swing arm or inside?
500ml of oil. I've put Castrol G3 ATF in today and it seems pretty good. You can get the year from the serial number.... Search function is your friend :)
There was a post about it not long ago I think.
  On 1/28/2012 at 11:16 PM, for artie said:
Check the 10th digit of the VIN number
1997 = V 1998 = W 1999 = X
Looks like its a 98 model then cheers
  On 1/29/2012 at 8:27 AM, Drake said:
Theyre Paioli forks. As I have already told you. Get that shock sorted asap as well :banana2:
How do you know shorty you not even seen it yet :P
