robbybobby Posted January 29, 2012 Report Share Posted January 29, 2012 Where my pipe comes out of the head it is turning a bluish purple. Someone told me i might be running lean. What do i adjust here? Quote Link to comment Share on other sites More sharing options...
steve fracy Posted January 29, 2012 Report Share Posted January 29, 2012 What kind of bike is it?? YOu are local too.... lots of good people in the club there to help out! STeve Quote Link to comment Share on other sites More sharing options...
robbybobby Posted January 29, 2012 Author Report Share Posted January 29, 2012 08 290. It was a couple club guys that said thats what it might be. Never thought to ask how to adjust it at the time. Im injured plus the weathers been kinda ***** so i haven't been to CPTA in a while and figured id ask on here (mostly out of boredom and the need to feel im part of the online community) Quote Link to comment Share on other sites More sharing options...
ham2 Posted January 29, 2012 Report Share Posted January 29, 2012 When it comes to Shercos I think it's brass/gold for too rich and green/blue for too lean. Quote Link to comment Share on other sites More sharing options...
steve fracy Posted January 29, 2012 Report Share Posted January 29, 2012 Try popping an email to the importer Mountain MC who are in your neighborhood too. Let them know I steered you that way, and see what they have to say. Lots of knowledge about Sherco and Beta there! Steve Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted January 29, 2012 Report Share Posted January 29, 2012 (edited) If the pipe is blue, It will be running way to lean, The engine and exhaust will be getting to hot and It will be having to work to hard. You need to richen it up If it's a Keihin carb the air/mixture screw is near the bottom on the side & you turn it in to richen. If it's a Dellorto (which it probably will be) I'd imagine the screw is the smaller one on the picture. Not sure if it's an air screw or mixture though. Edited January 29, 2012 by BenBeta23 Quote Link to comment Share on other sites More sharing options...
drake Posted January 29, 2012 Report Share Posted January 29, 2012 Just a thought on this, but if it's been retarded wont that also make the pipe hot? Quote Link to comment Share on other sites More sharing options...
copemech Posted January 30, 2012 Report Share Posted January 30, 2012 Just a thought on this, but if it's been retarded wont that also make the pipe hot? Yes it will, and I was just going to suggest that. Wonder if he knows where the timing is set, as many were set back to settle the bike a bit, but this tac come up specially is set back a bit too far! Quote Link to comment Share on other sites More sharing options...
robbybobby Posted February 2, 2012 Author Report Share Posted February 2, 2012 I dunno where the timing is set aside from the retarder switch. Quote Link to comment Share on other sites More sharing options...
copemech Posted February 3, 2012 Report Share Posted February 3, 2012 I dunno where the timing is set aside from the retarder switch. Best speak with the original owner for any info if you can. Otherwise it may need an inspection just to see where things are at. The "retard switch" on the bars only effects high rpm advance curve basically, and most riders cannot tell a difference, as this does not seem to effect base timing, yet base timing has a wide range of adjustment. Personally, I would remove it, but that is up to you. I have found that setting them back too far in an effort to settle the bike can do this. The good range is fairly narrow it seems, with 5-6mm rotation(counter, and roughly equate to degrees of timing BTDC) of the stator plate from factory settings being the maximum allowable without other ill effects such as this. The mid setting would be in the mid, at 3mm for example, and is where mine is now. Quote Link to comment Share on other sites More sharing options...
myzeneye Posted February 8, 2012 Report Share Posted February 8, 2012 mine went bluey purple right before my stator threw its hand in.... timing was set up ok, around tdc... bike began running mega hot, exhaust started to get so hot it almost metled the pastic trim on the silencer and discoloured the plasctic of the rear mud gaurd........ mega hot. pretty soon after the stator threw its hand in. timing or stator related.... Quote Link to comment Share on other sites More sharing options...
