pleb Posted January 30, 2012 Report Share Posted January 30, 2012 2005 pro 250. I have just polished the inside of my top hat and fitted new o rings and was after some advice on the best way to refill and bleed the system. is there a special lube to use on the new o rings? do I fill the top hat first? Quote Link to comment Share on other sites More sharing options...
lowbrow Posted January 30, 2012 Report Share Posted January 30, 2012 Good idea to fill the top hat so that any air is forced up the hose past the clutch case and banjo. The hose should then virtually self bleed if you fill the reservoir, turn the bars to make the master cylinder the highest part of the system and gently work the lever with very short strokes until no more tiny bubbles appear. Quote Link to comment Share on other sites More sharing options...
