Swm Tl320 Rear Wheel Spindle
taff4
Just removed the rear wheel to replace the wheel bearings. I found a short 'sleeve' rattling around when the spindle was removed.
So, should there be a full length sleeve between both wheel bearing inner races ?
Has anyone got a photograph of the rear wheel set up ?
Many thanks !
Edited by TAFF4
the tube needs to go from bearing inner to bearing inner to prevent bearings been over loaded or crushing
I rushed that a bit !
The tube was the correct length and everything fitted perfectly.
Thanks for the responses.
