cmc84 Posted February 3, 2012 Report Share Posted February 3, 2012 How can I get my flywheel off without having to take the bike to the shop? I've got a 2 arm puller somewhere in the garage, would that do it? Gonna stick on a new condenser and points tomorrow, see if that gets her running a bit better... Quote Link to comment Share on other sites More sharing options...
bondy Posted February 3, 2012 Report Share Posted February 3, 2012 How can I get my flywheel off without having to take the bike to the shop? I've got a 2 arm puller somewhere in the garage, would that do it? Gonna stick on a new condenser and points tomorrow, see if that gets her running a bit better... hi the flyweels arnt easy to remove if you havant got the right tool. not sure about the to arm puller but ud be beter of buying a flyweel puller from bultaco uk. and a flyweel holder to take the center nut of these cost about a tenner each money well spent if you plan on keeping the bike. you could try your puller what you have but i couldnt tell you if this would work. back in the day they used to tap it off with a hammer but i dont recamend doing this incase you do damage hope this helps Quote Link to comment Share on other sites More sharing options...
sherpagorri Posted February 3, 2012 Report Share Posted February 3, 2012 Don Quote Link to comment Share on other sites More sharing options...
copemech Posted February 4, 2012 Report Share Posted February 4, 2012 If you don't have the stuff, including proper micrometer or dial guage, best off taking to shop or you will be sorry! Quote Link to comment Share on other sites More sharing options...
cmc84 Posted February 10, 2012 Author Report Share Posted February 10, 2012 Copemech, I didn't think it would be that tough? The correct timing must be in the region of plus or minus a few dergrees rotation from where it has been scribed on the casing, and the points gap needs set 2-3mm (approx) before TDC. admittedly ive never done it, but is it that difficult? Quote Link to comment Share on other sites More sharing options...
