Clubman 80 Powerband?
mcman56
I have a 1993 clubman 80 (air cooled) that is new to me. Does anyone know what type of power to expect from this bike? It does have some pull down low that lets it chug at very low rpm on relatively flat ground. It also has some top end pull when it "gets on the pipe". However, the mid range is pretty flat and opening the throttle can just make it bog. I'm wondering if this is normal or if some improved jetting may help. It is intended for a new 100 lb rider and the lumpy powerband will make it more difficult.
