Gear Box Oil
lee_28
Its a big point of discussion fella,
Some use ATF dextron 3 because its a light oil and seems to help with the clutch, people tend to change this regularily.
Others run Putoline, Motul etc etc
Up to you really, Id do a search if you want to go into the ins and outs of each :thumbup:
In your GasGas you really want to use Global Racing Oil as its what GasGas recommended in the handbook. Its very good stuff, but its difficult to get hold of here. I heard recently that Andy Metcalfe motorcycles might stock it, maybe be worth giving him a call they're very helpful.
This info has been cut n pasted from the tech bulletin on trialpartsusa;
Transmission oil:
Recommend type: ATF DEXRON II
Alternatives: NOTE: We have a few customers using the type "F" automatic transmission oil with good results. Dramatically reducing, and in one known case eliminating the clutch pack swelling.
NOTE: GASGAS Spain recommends only Dexron III automatic transmission oil at this time.
Oil type warning:
DO NOT USE #12378508 GM auto-trac II (blue) oil
Never use synthetic oil in the transmission~clutch. The synthetic oils are
