nubee1974 Posted February 6, 2012 Report Share Posted February 6, 2012 I have a sherco 2000 which has the single waterpump seal. Would a 2001 onwards clutch case fit onto the 2000 model? The later clutch cases takse 2 waterpump seals that all. Cheers Quote Link to comment Share on other sites More sharing options...
copemech Posted February 7, 2012 Report Share Posted February 7, 2012 I have a sherco 2000 which has the single waterpump seal. Would a 2001 onwards clutch case fit onto the 2000 model? The later clutch cases takse 2 waterpump seals that all. Cheers It may fit, yet I cannot recall anyone doing a conversion, as seals are pennies! Add one still has issues of wear on the shaft, so other than possibly a bit of warning from the weephole(if it's not bunged up) little advantage. Quote Link to comment Share on other sites More sharing options...
tony27 Posted February 7, 2012 Report Share Posted February 7, 2012 Pretty sure it's a straight swap Quote Link to comment Share on other sites More sharing options...
nubee1974 Posted February 7, 2012 Author Report Share Posted February 7, 2012 (edited) Agree cope that's it doesn't make too much financial sense. But I can get one for very little and I thought it may be a better seal design. Do you not think its worth it then? Does anybody know if the rear mudguard from a later than 2000 will fit onto a 2000? Cheers Chris Edited February 7, 2012 by Nubee1974 Quote Link to comment Share on other sites More sharing options...
copemech Posted February 8, 2012 Report Share Posted February 8, 2012 Agree cope that's it doesn't make too much financial sense. But I can get one for very little and I thought it may be a better seal design. Do you not think its worth it then? Does anybody know if the rear mudguard from a later than 2000 will fit onto a 2000? Cheers Chris Could be, but I would first ck to ser if anyone knows for sure, as does not seem common practice. Try Splatshop Chris or email RYP in the US just to confirm, as tolerances here are critical. I have heard the later mudguards will fit, with modification. To what extent I am unsure. Quote Link to comment Share on other sites More sharing options...
