Chain Tensioner
upinthehills
I have a 4RT and the bike and trialing are new to me. I have noted that the chain tensioner on the left swinging arm has alot of play. Would anyone be able to tell me the correct description for this and what I need to order to sort the problem. The arm itself seems fine, it just the bush/bearing which seems to have failed.
cheers ali
Pretty sure it the same as a 315r, remove tensioner give the two bushs a good soaking with wd40,
Gently tap them out with a slightly bigger socket, replace with new,,
check tensioner shaft for wear, and replace if worn,,
(that should remove all side play)
