Clutch Cover Gaskets For Dummies
cmc84
I'm wondering if the case is a bit buckled. it used to be a drip, but since I've been testing the bike it's really coming out in a hurry.
What would you do - make a thicker gasket, or get the casing faced maybe?
The standard seal slightly greased and the cover shoud fit thight.
You can check your cide case by placing is on a glas plate if the
the side case is only slighly wrapped you can mount a big sheet of
grindpaper for metal with duct tape on the side on the glas surface.
Then you might grind the side case edges with water and rotary movement
to align them again, (this works only if there are one some tenth of mm to align).
Might sometimes be a problem too, (I had this issue), check the drain screw for
the clutch oil, mine must have got a hit from the stones and was slightly bend
so the head of the srew did not seal the drain hole proper.
