Montesa Mh200
yamaha250
Hi there, all new to me , but i have been restoring a cota mh200, serial no,6c119 ?
Anyone know 1. where drain plug for gearbox is?
2.what year is it?
3.does anyone have pictures of same model
4. Is the tank ok for modern unleaded, no leaks at present.
5. was any mods done to improve
6. pre mix ratio (i use putoline mx5)as i have beta rev3 also.(100mmper gal)
Many thanks in anticipation, cant find much about this bike.
Carl
Anyone know 1. where drain plug for gearbox is?under the bash plate it has to be removed
2.what year is it?1984 ish
4. Is the tank ok for modern unleaded, no leaks at present.poliprop yes grp no
5. was any mods done to improve hmmm lower foot rests
6. pre mix ratio (i use putoline mx5)as i have beta rev3 also.(100mmper gal)40:1
Carl
2.what year is it?
Carl
hi montesa cota 200 175cc ran from 1980 to 84 mh been the later model as far as i am aware the cota 200 frame number started 29m or a cota172 19m (74 to 77 ), i too have looked for a drain and have only found one on right clutch case but the frame prevents it from been undone ,, it is best to seal tank inside with a ethanol proof sealant look on ebay, as for mods ,mine has a lengthened swing arm and am thinking of fitting pegs further back and slightly lower,as for fuel when you say gallon is that 4.5 litre or 5 litres ? or a full plastic type fuel can ? as theres a big difference ,you need to work on 5litres (5000ml) at 100ml oil = 50-1 ok for the mont if semi syn or fuuly syn the rev 3 could use slightly less oil ie 90ml to 66ml = 55 to 1 or 75 to 1 i use 90ml to 5litres in my rev3 and 100ml in the mont google montesa cota 200 pics and you should find plenty
