Engine Oil / Clutch Oil ?
biggwil
Hi I have an 84 mh200 and have similar questions to everyone else. I removed the sump guard to find no obvious drain plug for oil. Found one on the right hand casing which was awkward but not impossible to remove . I'm a bit concerned with people saying clutch / gear oil separate on these bikes . Can anyone tell me what's what with regard to what oils , and quantities and location of sump plug ??? I have removed 1200 ml from the right hand plug . Do I replace this with light gear oil or something else ? Is there anywhere that I can obtain a workshop manual ?
they share the same oil so light gearoil should be fine or maybe atf unless someone knows differnt ,, put same amount back in ,ive not found another drain, try southwest montesa for manual
