Bleeding Clutch On Gas Gas Raga?
mill9898
Hi mate yes 05 onwards uses mineral oil in the clutch.and as far as bleeding you must always back bleed a clutch on a gas gas you will need to take the top of the slave make sure oil is low as when you force the oil back it will fill up, use a shringe with a piece of rubber hose on so it will fit on the bleed screw open bleed screw force oil back up to the top hope this helps mate.
Edited by nigel28
