bmseven Posted February 19, 2012 Report Share Posted February 19, 2012 (edited) I couldnt find an 02 either and it does look identical to the 03 125 on the Gas gas Museum site Shouldnt the cc be stamped on the base of the barrel? Edited February 19, 2012 by bmseven Quote Link to comment Share on other sites More sharing options...
mike2012 Posted February 19, 2012 Report Share Posted February 19, 2012 Jon Thanks for your efforts, as I'm very new to the trials game every little bit of info helps. I did a little digging myself and came up with this of the web. http://motorcycle-specs.com/motorcycle_specification.asp?manufacturer=Gas%20Gas&model=TXT%20200%20Pro&year=2003 Thanks once again Mike. Quote Link to comment Share on other sites More sharing options...
jse Posted February 19, 2012 Report Share Posted February 19, 2012 I couldnt find an 02 either and it does look identical to the 03 125 on the Gas gas Museum site Shouldnt the cc be stamped on the base of the barrel? Like Mike has researched, it's probably an 03'. Usually the relative cc's (in general) are cast on the cylinder on a small circle, left side I think, such as "30"=300 model, "28"-280 model, "25"=250 model etc. Not always a perfect indicater, however, and "370cc" was cast into the cylinder of my 96' JTR370, but it was actually a 338cc capacity. I'm guessing the prototype was 370cc's but proved to be too much of a handful, but they kept the cylinder casting assembly for production use. Jon Quote Link to comment Share on other sites More sharing options...
