yellow_cad Posted February 19, 2012 Report Share Posted February 19, 2012 I got the OSSA World clutch springs that are softer than stock. Seems like I should be able simply just to replace one spring at a time with the primary cover off, readjust my clutch, and I'm on my way. I'm just checking to see if that method is fine. Thanks for any thoughts. Jim Quote Link to comment Share on other sites More sharing options...
feetupfun Posted February 19, 2012 Report Share Posted February 19, 2012 I got the OSSA World clutch springs that are softer than stock. Seems like I should be able simply just to replace one spring at a time with the primary cover off, readjust my clutch, and I'm on my way. I'm just checking to see if that method is fine. Thanks for any thoughts. Jim Yes changing the springs like you said is fine and you shouldn't need to do any adjustment of anything. Quote Link to comment Share on other sites More sharing options...
