avo Posted February 19, 2012 Report Share Posted February 19, 2012 i was wondering can you change the gearing in the new randonne to be more like a trials gearbox than a trail bike gearbox? thanks Quote Link to comment Share on other sites More sharing options...
cota200 Posted February 19, 2012 Report Share Posted February 19, 2012 (edited) Hello there. Hope this helps. At least in Spain the bike comes with an alternative front sprocket for trials use. Also Mitani has developed a front pipe without a cathaliser. Horsepower drop with the restrictive cathaliser. If you want the bike to perform similar to a Scorpa 125F you must do both: change front sprocket and either remove cathaliser (cut and weld) from the original pipe or buy a Mitani substitute. Have a look http://www.mitani-ms.jp/new-products/image/20111107/randone-ex-1.jpg Regards from Spain Edited February 19, 2012 by cota200 Quote Link to comment Share on other sites More sharing options...
faktree Posted February 19, 2012 Report Share Posted February 19, 2012 i was wondering can you change the gearing in the new randonne to be more like a trials gearbox than a trail bike gearbox? thanks Hi avo... Have you fitted the 11 front and the 42 rear that comes with the bike from standard???? (on it when new should be 13 x 38) You can fit a 48 tooth rear and we (GGUK) are having some 10 tooth fronts made as we speak.... we have 10 x 48 on our demo and its fine for trials. Faktree.... Quote Link to comment Share on other sites More sharing options...
avo Posted February 19, 2012 Author Report Share Posted February 19, 2012 i havent bought one yet i was just wondering because when i went on one it felt quick and just wondered if you could change the actually gearing in the bike. thanks for you help guys Quote Link to comment Share on other sites More sharing options...
dean_dabs Posted April 14, 2016 Report Share Posted April 14, 2016 Looking for a vendor for the 10/48 sprockets. I'm picking up a 200 randonne this weekend. Dean@learntoride.org 615 545 1111 Old hickory, Tennessee USA Quote Link to comment Share on other sites More sharing options...
sectionone Posted April 14, 2016 Report Share Posted April 14, 2016 The newer models use a chinese motor that is a copy of the yamaha ttr motor. Quote Link to comment Share on other sites More sharing options...
