Gas Gas Randonne
avo
Hello there. Hope this helps.
At least in Spain the bike comes with an alternative front sprocket for trials use. Also Mitani has developed a front pipe without a cathaliser. Horsepower drop with the restrictive cathaliser. If you want the bike to perform similar to a Scorpa 125F you must do both: change front sprocket and either remove cathaliser (cut and weld) from the original pipe or buy a Mitani substitute.
Have a look
http://www.mitani-ms.jp/new-products/image/20111107/randone-ex-1.jpg
Regards from Spain
Edited by cota200
  On 2/19/2012 at 6:08 PM, avo said:
i was wondering can you change the gearing in the new randonne to be more like a trials gearbox than a trail bike gearbox?
thanks
Hi avo...
Have you fitted the 11 front and the 42 rear that comes with the bike from standard???? (on it when new should be 13 x 38)
You can fit a 48 tooth rear and we (GGUK) are having some 10 tooth fronts made as we speak.... :thumbup: we have 10 x 48 on our demo and its fine for trials.
Faktree....
  • 4 years later...
