cje315r Posted February 19, 2012 Report Share Posted February 19, 2012 hi,just bought a montesa 315r 2000. Its my first bike and needs some repairs to the engine, this included a new top end which the seller stated on the advert. Just wondering if anybody could tell me what specific parts i would need to replace, the piston needs replacing and the cylinder is badly scored. Any help would be much appreciated, particularly a place where engine parts are available, prefferably in the Leeds/Wakefield area. Thanks Quote Link to comment Share on other sites More sharing options...
md04 Posted February 19, 2012 Report Share Posted February 19, 2012 On 2/19/2012 at 8:45 PM, cje315r said: hi,just bought a montesa 315r 2000. Its my first bike and needs some repairs to the engine, this included a new top end which the seller stated on the advert. Just wondering if anybody could tell me what specific parts i would need to replace, the piston needs replacing and the cylinder is badly scored. Any help would be much appreciated, particularly a place where engine parts are available, prefferably in the Leeds/Wakefield area. Thanks Hi there i use Pidcocks for parts just tell them whats wrong with the bike and they will tell you what you need parts wise, it will need the barrell rebored or replated(which ever can be done)also piston & rings,gudgeon pin,small end bearing,circlips,head gasket & base gasket.It would be wise at this stage to check for play in the big end too (side to side ok its the up & down movement you dont want)hold the conrod and try to move it up & down on the big end bearing if your unsure get someone check it over who does as it might not need done.You might want to check the condition of the main bearing oilseals,if your bike needs the big end done tho you would automatically change the main bearing and seals and any other parts that need done while the cases are split depending on the depth of your pockets. Hope this is of some use and you only need some of the above... Quote Link to comment Share on other sites More sharing options...
canada280i Posted February 19, 2012 Report Share Posted February 19, 2012 Sandifords or Pidcocks to get the actual parts. What you will need is to firstly get the barrel redone and matched to the correct over size piston depending on which one is already in it. Then you just need the actual piston kit which is the actual piston, the ring set (3), new top end bearing, new wrist pin, 2 new circlips, new head and base gaskets. You can probably buy everything as a kit, if not the dealers should be able to put everything together for you. Changing the piston is quite an easy job, but if you are not very mechanical you can have someone do it for you. I did mine over the long winter months here in Canada, riding when its minus 20 is no fun. Quote Link to comment Share on other sites More sharing options...
lee99780 Posted February 20, 2012 Report Share Posted February 20, 2012 Hi cje Ive found a complete piston kit on ebay, there is a few parts on there for your model. Quote Link to comment Share on other sites More sharing options...
magicmat Posted February 20, 2012 Report Share Posted February 20, 2012 Hi there, did you buy the bike from a Bloke in doncaster? I cant get link to the add atm, but if your bike: has a carbon effect tank, a 4rt front mudguard and the owner did a new: airfilter, brake pads etc Then its the one i looked at, and i may have some extra information for you Matt Quote Link to comment Share on other sites More sharing options...
cje315r Posted February 20, 2012 Author Report Share Posted February 20, 2012 Yeah sounds like the same bike ,contact me on 07950423903 Quote Link to comment Share on other sites More sharing options...
sharkbait Posted February 20, 2012 Report Share Posted February 20, 2012 You could also try FeetUp Trialsport. I had excellent service and advice from them and they can sell you an exchange matched piston and barrel. Quote Link to comment Share on other sites More sharing options...
cje315r Posted February 20, 2012 Author Report Share Posted February 20, 2012 Thanks for all advice ,much appreciated Quote Link to comment Share on other sites More sharing options...
magicmat Posted February 22, 2012 Report Share Posted February 22, 2012 I've also used feetuptrials sport recently for my beta parts, very good service Im going to send you a message on here fella. Matt Quote Link to comment Share on other sites More sharing options...
montyhack Posted February 23, 2012 Report Share Posted February 23, 2012 I too have recently used Feetup Trials after loosing all confidence with sandifords, Alan is very helpfull and i got the piston kit next day. hope you get sorted for not too much cash! Quote Link to comment Share on other sites More sharing options...
manofsteele Posted February 26, 2012 Report Share Posted February 26, 2012 Yep. Another nod to Feetup Trialsport from me. Recommended. Quote Link to comment Share on other sites More sharing options...
cje315r Posted February 27, 2012 Author Report Share Posted February 27, 2012 Yep, rung the guy there and he was very helpful and give me the total cost there and then ,i will be sending it off at some point next week thanks again for the advice people Quote Link to comment Share on other sites More sharing options...
