wrmec Posted February 20, 2012 Report Share Posted February 20, 2012 hello. i went to take the cylinder head off my 300cc 2006 gas gas txt pro and found one of the heads on the allen bolt has been rounded so i cant get it out. can anyone give me any advice what i could do. thanks. Quote Link to comment Share on other sites More sharing options...
fellonmelug Posted February 20, 2012 Report Share Posted February 20, 2012 Try gripping the head with small stilsons or other pipe gripping tool , or you could use Stud extractors Quote Link to comment Share on other sites More sharing options...
02-apr Posted February 20, 2012 Report Share Posted February 20, 2012 hello. i went to take the cylinder head off my 300cc 2006 gas gas txt pro and found one of the heads on the allen bolt has been rounded so i cant get it out. can anyone give me any advice what i could do. thanks. Tap in a torx bit with a hammer then turn that. Or cut a slot with a dremel type tool. Quote Link to comment Share on other sites More sharing options...
nigel28 Posted February 20, 2012 Report Share Posted February 20, 2012 (edited) if you was closer to me i would have told you to bring it to me i would have done that for you mate free,if you knock a torx bit in and give it a thump using a impact driver they do help you mate Edited February 20, 2012 by nigel28 Quote Link to comment Share on other sites More sharing options...
lineaway Posted February 21, 2012 Report Share Posted February 21, 2012 Pop it once with a hammer to break the threads loose. Then use a small chisel to loosen. Or just drill the allen head out and remove the head then use vise grips to remove rest of bolt. Quote Link to comment Share on other sites More sharing options...
wrmec Posted February 21, 2012 Author Report Share Posted February 21, 2012 Thanks for the replies. i managed to get it by cutting a little slit in with a hacksaw and tapping it round with a screwdriver. i usually drill bolts out when the heads get worn but i didnt like to do it on the cylinder head. Quote Link to comment Share on other sites More sharing options...
jse Posted February 21, 2012 Report Share Posted February 21, 2012 Thanks for the replies. i managed to get it by cutting a little slit in with a hacksaw and tapping it round with a screwdriver. i usually drill bolts out when the heads get worn but i didnt like to do it on the cylinder head. Cut off and dress about 5mm from the end of your old Allen wrenches and you will probably not strip any more. Jon Quote Link to comment Share on other sites More sharing options...
