mattylad Posted February 21, 2012 Report Share Posted February 21, 2012 Does anyone have the length of the spacer required when removing the speedo on a drum brake mono? Thanks Quote Link to comment Share on other sites More sharing options...
jse Posted February 21, 2012 Report Share Posted February 21, 2012 Does anyone have the length of the spacer required when removing the speedo on a drum brake mono? Thanks I measured mine (without taking the wheel off) and I think that 25mm should do. The axle step bottoms on the spacer and pushes it in so the length does not have to be perfect. I machine my own and cut an o-ring groove on the spacer where it fits into the drum and use an o-ring to keep grit out of the bearing area. Jon Quote Link to comment Share on other sites More sharing options...
