Cylinder Head Heli Coil?
christopherd
All the cylider head holes look like they have heli coil repairs in them..... Or is this how they come from the factory?
As I have had the head off a few times of late three of the repairs look loose and will not torque up....
How should I proceed.
Insert a new coil?
Drill and re-tap the hole? What size is a repair for a M6??????
Thanks in advance for your help.
Insert a new coil?
Sounds like the previous owner was not a believer in torque wrenches. Depending on the quality of the repair, you may want to
re-insert a new coil and invest in new capscrews that don't have worn threads.
Jon
Think the drill bit is 6.3mm . Always kits like this on ebay http://www.ebay.co.uk/itm/V-COIL-M6-X-1-0-HELICOIL-TYPE-THREAD-REPAIR-KIT-/270905326007?pt=LH_DefaultDomain_3&hash=item3f133739b7 or try your local bolt supplier .
Be hard work drilling the old one's out , the inserts are stainless , maybe try pulling them out , you mite have to go up a size (M7 - M8) if the holes as been drilled slightly over .....Good luck....
It sounds like you'll have to re-helicoil the barrel, if you've not done this before or are not familiar with the helicoil process I'd advise taking the barrel to an engineer to have it done. The Kits often come with the correct size drill for the special helicoil tap but not always, this has to be right! To drill and fit helicoils to all 6(?) holes in the barrel would take less than an hour for a decent engineer, once they are replaced they should never need doing again.
