legs Posted April 14, 2005 Report Share Posted April 14, 2005 (edited) Electronic ignition for all Bultaco Sherpa trials bikes now available, see www.bultacouk.com Edited April 14, 2005 by Legs Quote Link to comment Share on other sites More sharing options...
arun1664 Posted April 14, 2005 Report Share Posted April 14, 2005 A mate of mine has just fitted one to his 350, it works very well. I think he misses taking it apart every couple of weeks but you can't win them all. Plus the system is not electronic (no black box), it is completely inductive which is kind of neat. Quote Link to comment Share on other sites More sharing options...
trialsrfun Posted May 8, 2005 Report Share Posted May 8, 2005 sounds like a good idea does anyone know do they fit on without altering anything & how easy is it to time etc any difference to the bottom end power better or worse ? bike is a 350 199A Quote Link to comment Share on other sites More sharing options...
arun1664 Posted May 15, 2005 Report Share Posted May 15, 2005 To fit the system my mate has (Renham), you have to remove both the ignition & lighting coil along with the points assem, then you bolt the the new assem in. Timing is by setting a mark on the new assem a set distance from a fixing screw. Sloted holes provide adjustment. The coil is replaced also. Bike runs much smoother is (a bit) more responsive and is less prone to tickover variation as it gets hot (he says). Hope this helps ... Quote Link to comment Share on other sites More sharing options...
