gaff Posted January 1, 2004 Report Share Posted January 1, 2004 Just curious, what air-filters do you lot use in your RTL's, currantly i'm using a Montesa 314's, not a great fit, but is what i have been advised to be the closest thing. Thanks in advance. Gaff. PS. Happy New Year. Quote Link to comment Share on other sites More sharing options...
d. sileo Posted January 1, 2004 Report Share Posted January 1, 2004 This probably not the best method but I use the stock air filter lid, and with that in hand I buy some filter element foam panels and construct my own using the lid as a guide. You can cut and glue the foam pcs. together and them I have my wife sew it on to the lid.... Looks like the orginal and holds up a bit longer... I do not know of anywhere to buy an RTL filter.....I have also used a 315 filter, a 314 filter a beta techno filter, all cut to size and then mounted to the original lid........Probably didn't help you much but custom made filter are not difficult to construct......Ishy may have a better solution.........D Quote Link to comment Share on other sites More sharing options...
