Air Gap In 2008 Txt Forks
MontyTim348
Does anyone know what the air gap should be on a 2008 280cc TXT. I've managed to download the manual and on page 11 it says 180mm and on the diagram on page 30 it says 180mm. Does anyone know which is correct.
I would say 180mm then :hyper:
If you have the Al tubed Marzocchi forks - the air gap = 160mm
If you have the steel tubed Sachs forks (or pre 06 Steel Marzocchi's) - the air gap = 180mm
The wall extra wall thickness of the AL tubes accounts for the height difference as both forks use the same volume of fluid.
