Bultaco Sherpa T 199 Sprockets
steve01
Hi, I've recently brought a 1978 Sherpa and it's on standard sprockets 13/46 and I think it's a bit too tall for trials. Any suggestions on better sizes? I will need to buy chain and sprocket set, so want to get it right first time. I hope someone can help.
Whilst 13/46 sprockets were fitted when the bike was new things have changed, nowadays there are less and dependent on where you ride possibly no road based trials so the higher gearing could now be a disadvantage and reducing the front sprocket to 11 or 12 might be better.
i was told 11 front and 39 rear was made standard on the 199A so ive stuck with it. ive had no problems with this gearing. i was thinking of going biger but to be honest i dont know what would be the best. ive allready got new sprockets so ill stay with what ive got.
ATTENTION: Sprockets for 199 model are diferent that for 199a and 199B !!!!!
The one I use 13 / 48 or the alternative lower 12 / 46 are good for 199 model, NOT for 199a and 199b gear box is not the same.
Original for 199 is 13 / 46
Original for 199a and 199b is 11 / 39
I think you will find that the 199 and 199A and 199B all have the same gearbox other than the six speed in the 199B and you can use either combination of gearing to get the same result. The gear that concerns most of us is 1st
Using 11/39 1st gear is 37.7:1
Using 13/46 1st gear is 37.6:1
Basically no difference other than you have a much smaller rear sprocket
Earlier models before the 199 series run 11/46 which gives a 1st gear 37.8:1
So all bikes have the same 1st gear ratio with the factory gearing
The 199, 199A and 199B have different internal gears to the previous models, the change was made to give the bikes a higher top speed for events like the Scottish Six Day
Hope this helps Greg
Edited by sherpa325
That is correct sherpa325 !!!!
It is more complicated even, as:
For 198/199 and 198A/199A & 198B = 0,223 / 0,287 / 0,376 / 0,612 / 1
For 199B = 0,223 / 0,287 / 0,361 / 0,512 / 0,739 / 1
I just thought it was more simple to understand to put it like this:
Original for 199 is 13 / 46 if you want more control in the sections go to 13/48 or even slower 12/46 changing front or rear.
Original for 199a and 199b is 11 / 39 the same !!!!
Edited by Greeves
