Rev 4t Running Poorly
neilnh
Hi
Have you checked in the base of the air box, oil can collect within the air box after a big off.
Then when you hit a step some of the oil can be pulled into the carb and cause poor running.
We had this problem and found the above, once cleaned out it was sorted, you may need to clean the carb as well.
Edited by JFC
Clean the carb out. I am not familiar with this carb but asume it has a cold start enrichment system. Make sure this is closing off properly when not in use. Float level? dirt on or damaged float valve seat?
Occasionally faulty HT coil gives same symptoms.
Run the bike with the fuel turned off and see if problem goes as the carb empties - if it does you know flooding or similar is problem.
Cheers
  • 1 year later...
I too have a problem with my recently purchsaed 4t.
It Starts ok idles ok but has a really annoying flat spot on about 1/6 throttle. Past this point
everyting is sweet again.
New plug fitted carb drained but not stripped.
Any suggestion?
