mattylad Posted March 13, 2012 Report Share Posted March 13, 2012 I am trying to remove the rear spring of a R model shock with the remote reservoir. When I unscrew the preload retaining collar it will not slide off as it catches on the damping adjuster. What do I need to do??? Quote Link to comment Share on other sites More sharing options...
handsome_al Posted March 16, 2012 Report Share Posted March 16, 2012 Well I've searched the workshop manual and replacing a spring does not get mentioned. What is mentioned though is the Damper Rod or Oil Seal, if damaged - replace the whole unit! It does not say 'why' (ie. spares unavailable etc) therefore this leads me to think it's none-dismantle-able.... ...... also the manual goes into great depth about using the correct method for disposing of the shock !!! Someone out there MUST have tried this before. Quote Link to comment Share on other sites More sharing options...
dougalthedog Posted March 17, 2012 Report Share Posted March 17, 2012 I think the only way you can remove the spring is to undo the base of the assembly from the damper rod (assuming the damper rod is threaded) The problem is the limited amount of room to get a fix on the rod due to the reservoir hose joint preventing the spring from being moved very far. Ive tried loads of times in the past and even had a "proper motorcycle mechanic" have a look and we have had no success. You could try ringing Nigel Birkett - at least you would find out for sure if they can be dismantled. Quote Link to comment Share on other sites More sharing options...
barfy Posted May 14, 2017 Report Share Posted May 14, 2017 Did anyone find an answer to this question, because I want to do the same thing? Cheers Quote Link to comment Share on other sites More sharing options...
