westygas270 Posted March 13, 2012 Report Share Posted March 13, 2012 Hi what make do pepople recomend for engine oil on 300 evo? i have been using putoline b4 but what does every1 use?? if so what putoline is best?? Quote Link to comment Share on other sites More sharing options...
haggi961 Posted March 13, 2012 Report Share Posted March 13, 2012 Cant go far wrong with the Putoline range, i also put the Putoline Light gear oil in my evo 250 and so far its been fine. I also use the Putoline TT Trial Pro Strawberry 2 stroke oil. Quote Link to comment Share on other sites More sharing options...
helloyes Posted March 13, 2012 Report Share Posted March 13, 2012 (edited) wouldn't put that in a lawnmower !! mobil 1 all the way in mine always best to stick to oil from a large manufacture they have the most money the best chemists and therefore the best oils so mobil/shell/castrol/elf are the best choices in my opinion i asume you have a evo 300 4t ? 2stroke oil same rules apply, 2t gearbox oil elf is the only oil that stops the plates sticking Edited March 13, 2012 by helloyes Quote Link to comment Share on other sites More sharing options...
westygas270 Posted March 13, 2012 Author Report Share Posted March 13, 2012 evo 300 2 stroke "Hell0yes" yes think i might try one of them you said think is lot do use putoline tho Quote Link to comment Share on other sites More sharing options...
totalshell Posted March 14, 2012 Report Share Posted March 14, 2012 given the limited use in hours and mileage between engine changes frankly almost any oil will be satisfactory.. I have had since new a 9 yr rev3 and its always had cheapest oil and changed every month. my fantic and francis barnett both have the same oil and one of them is used every weekend. 1 Quote Link to comment Share on other sites More sharing options...
pindie Posted March 14, 2012 Report Share Posted March 14, 2012 I agree. Any light gear is fine as long as it is changed regularly. Quote Link to comment Share on other sites More sharing options...
chewy Posted March 14, 2012 Report Share Posted March 14, 2012 Do I understand Helloves correctly Elf 2T gearbox oil.....we have a brace of 2012 Evos and the plates sticking together is a real pain..not only do you get /give the gearselection/box a hard time but delayed disengagement is not what you would call cutting edge tecnology in any motor sport let alone trials. Quote Link to comment Share on other sites More sharing options...
pindie Posted March 14, 2012 Report Share Posted March 14, 2012 Why is that trials bikes seem to be the only thing on the planet that has constant clutch woes of one sort or another? The manufacturers need a slap! Quote Link to comment Share on other sites More sharing options...
myzeneye Posted March 15, 2012 Report Share Posted March 15, 2012 (edited) im using castrol transmax dex 3 automatic transmission fluid (ATF), 50ml less then betas recomendation.... clutch works a treat.... that differance in 50ml of oil makes a differance... try it. Edited March 15, 2012 by myzeneye Quote Link to comment Share on other sites More sharing options...
totalshell Posted March 15, 2012 Report Share Posted March 15, 2012 on the issue of clutch's.. how many other applications can you name where it is only used once a week ,when in a 3-4 hour period the engines in fact is only run for half that time and the clutch is constantly slipped / ragged whilst under load for probably 40 minutes ( a minute a section) then the engine is stopped cold water is thrown over it / sprayed and then ignored for the next 6 days.. i think i'd stick too! 2 Quote Link to comment Share on other sites More sharing options...
