drongo Posted March 15, 2012 Report Share Posted March 15, 2012 I have fitted a set of new clutch plates but still get slip in the higher gears, 4th, 5th ,6th.Do not feel any slip in lower gears. There is free play at the lever & the action is light & smooth.Any thoughts? Also my rear brake plate broke at the swing arm location pin, is this a weak point or I am unlucky? My wonderful machinist friend made me a new one. Quote Link to comment Share on other sites More sharing options...
gasgas249uk Posted March 15, 2012 Report Share Posted March 15, 2012 Try a very light gear oil or ATF re the slipping.The oil will disperse from the plates quicker. If this fails , replace the springs as they are probably old and saggy after all those years Quote Link to comment Share on other sites More sharing options...
drongo Posted March 15, 2012 Author Report Share Posted March 15, 2012 Ok will give that a go. Then try some new springs if needed. Thanks Quote Link to comment Share on other sites More sharing options...
totalshell Posted March 15, 2012 Report Share Posted March 15, 2012 the springs are only a couple of quid whip em in job done. Quote Link to comment Share on other sites More sharing options...
