skippy1234 Posted March 15, 2012 Report Share Posted March 15, 2012 hi all ,took me fly wheel cover off me rev 3 to see if there was up and down movement off the fly wheel as there is exessive vibration and thought maybe mains had gone ,but i have a lot of in out movement is this normal and could it have something to do with the odd knock i thought was detonation-thanks Quote Link to comment Share on other sites More sharing options...
naichuff Posted March 15, 2012 Report Share Posted March 15, 2012 Sounds like to much end float Remove the clutch side case check the primery gear on crank is not loose or bearing on that side that has failed Quote Link to comment Share on other sites More sharing options...
skippy1234 Posted March 15, 2012 Author Report Share Posted March 15, 2012 ive took clutch cover off abd the bolt on the primary gear is tight Quote Link to comment Share on other sites More sharing options...
gasgas249uk Posted March 15, 2012 Report Share Posted March 15, 2012 How much movement have you got in MM? Is the crank moving or just the flywheel? Check that the flywheel nut hasnt come loose Check that the washer behind the nut is fitted. Without this there maybe insufficent thread on the crank to wind the nut on far enough Quote Link to comment Share on other sites More sharing options...
skippy1234 Posted March 15, 2012 Author Report Share Posted March 15, 2012 (edited) hi,by visual it looks 2/3mm max its on its side as ive took clutch casing off,the crank is moving as well,thanks it gives a clunk when moving it fast Edited March 15, 2012 by skippy1234 Quote Link to comment Share on other sites More sharing options...
0007 Posted March 16, 2012 Report Share Posted March 16, 2012 That's not unusual, you would need to check it at full operating temp to see if thermal expansion changes it To diagnose end play knock or "thrust" we used to push the crank end at the nut with a hammer handle with the engine running and see if the sound changed Quote Link to comment Share on other sites More sharing options...
dadof2 Posted March 16, 2012 Report Share Posted March 16, 2012 Do you mean the play is 2/3 rds mm (0.66mm) or 2 to 3 mm. A Rev3s main bearings may be geting tired by this time. I would not run the engine until the mains have been properly checked, it could ruin the crank, the big end the lot (very expensive). The vibration can vary. As the bearing cage wears or or starts to come apart the balls move, causing slackness at times and overtignness at others. Cheers Quote Link to comment Share on other sites More sharing options...
skippy1234 Posted March 16, 2012 Author Report Share Posted March 16, 2012 hi its 2-3 mm normal mms as on a tape measure ,cheers Quote Link to comment Share on other sites More sharing options...
chewy Posted March 16, 2012 Report Share Posted March 16, 2012 That can't be right....0.2mm maybe ...If it was vibrating bad before you stopped it I would suspect not only knackered bearings .big end but crank balance as well. Quote Link to comment Share on other sites More sharing options...
lee harris Posted March 16, 2012 Report Share Posted March 16, 2012 That can't be right....0.2mm maybe ...If it was vibrating bad before you stopped it I would suspect not only knackered bearings .big end but crank balance as well. yet i would say your mains are awol Quote Link to comment Share on other sites More sharing options...
skippy1234 Posted March 30, 2012 Author Report Share Posted March 30, 2012 if i tilt the bike over to the left it rumbles but no noise when leant to the right Quote Link to comment Share on other sites More sharing options...
gasgas249uk Posted March 30, 2012 Report Share Posted March 30, 2012 The flywheel just shouldnt have any movement at all. If someones not fussy theyll put up with a bit of movement , but i wouldnt.It would be nagging me to sort it. If your crank pulls through the mains bearings by 2mm, then something is badly worn. The rumbling when you lean the bike is because one mains bearings is more knackered than the other. It needs rebuilding mate, new mains and seals may sort you out if you cross your fingers and toes - ha ha Your local bike dealer will be able to rebuild this fairly cheaply, or you may wish to have a go yourself Good luck Quote Link to comment Share on other sites More sharing options...
skippy1234 Posted April 6, 2012 Author Report Share Posted April 6, 2012 was the mains ,fitted new ones ,now no play at all ,slight top end rattle now tho-but a great tight engine ,had trouble with clutch but got a syringe from cake shop and back bled in 1 minuete Quote Link to comment Share on other sites More sharing options...
