Changing Rear Brake From Lhs To Rhs
solvent3
Hi as the title says i would like to change my brake pedal from the current LHS to the RHS on my FB. My other bike is RHS brake and i feel much more comfortable and balanced this way.
so im planning on running a cable through from the RHS to get back to the LHS to operate it. Theres a picture of Norman Shepherd on the yorkshire site members photo and he has this setup, but i just wondered what the setup was like on the opposite side of the bike.
the plan is to maybe weld a block on LHS at rear, tap it, and then use a cable stop adjuster like you get in the universal clutch/brake cable kits.
Anyone have any ideas or guidance what to do or more importantly not to do?
thanks..
  On 3/23/2012 at 8:26 PM, Old trials fanatic said:
Wow not struck on the tank and hardly scottish legal but when it's finished i bet that makes a tidy bike. Is it yours?
No, not mine, the frame is one of a short run. I had saved the pic. Obviously the tank is a slave item to run the bike.... :rolleyes:
  On 3/20/2012 at 7:44 PM, totalshell said:
one enterprising lad at yarkshire classic ( he lives in lancashire though..) has a brake on both sides of his cub!
As the enterprising lad I would if I new how to put a picture on the forum i would. The reason the brake is on both side is the way I did it, it still needed part of the old brake lever to work so I just left the whole thing in place.
Jack
