Forkzzzz
md04
The owners manual has a pretty good description of procedure. As far as forks go, this one is not very complicated. So if you don't have a manual, then search the web for how to take apart a conventional cartridge fork.
The only special tool is a cartridge holder, which you can make yourself, or you can do without it if you have an air impact wrench to remove the bottom fork bolt.
