stonezone Posted March 26, 2012 Report Share Posted March 26, 2012 These things are horrible to work with and a pain to take on/off... http://trialstribulations.net/index.php?main_page=popup_image&pID=324 any interesting mods that you guys are using instead? thanks! SZ Quote Link to comment Share on other sites More sharing options...
jordi Posted March 26, 2012 Report Share Posted March 26, 2012 Always put the airbox assembly on before the fuel tank. What exactly is your problem? Quote Link to comment Share on other sites More sharing options...
fellonmelug Posted March 26, 2012 Report Share Posted March 26, 2012 Make sure you gently nip the clip part of the fixing ,that will ensure it stays nicely tight to the frame and wont fall off , gently with a pair of pliers usually does the trick Quote Link to comment Share on other sites More sharing options...
stonezone Posted March 27, 2012 Author Report Share Posted March 27, 2012 They are just an overall pain to work with. even when i nip them they tend to slid out of place when slide the whole unit over and onto the carb... I was thinking, maybe just some plastic pop-in plugs or something instead? Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted March 27, 2012 Report Share Posted March 27, 2012 I hear ya! When you find a solution, let us know! I have seen something that's a rubber plug with a threaded metal insert....are they called well nuts? I'm going to look around. I just went through this, so the hassle is fresh in my mind! Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted March 27, 2012 Report Share Posted March 27, 2012 The ability to move is their beauty, you get the plastics perfect every time, guess it allows variation in manufacturing? If yours are moving buy new ones they are v v cheap. Quote Link to comment Share on other sites More sharing options...
ham2 Posted March 27, 2012 Report Share Posted March 27, 2012 ...........What exactly is your problem? Man, that's fighting talk round here! Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted March 27, 2012 Report Share Posted March 27, 2012 I am not sure about your application but sometimes you can replace clipnuts like you show with nutplates. The plate gets pop rivited to in place and the nut portion can still move around to align with the fastener. You may find these at a local hardwae store search for them on the web. Google "Self-Locking Nut Plate, Floating" Quote Link to comment Share on other sites More sharing options...
tonyr6 Posted April 4, 2012 Report Share Posted April 4, 2012 i overcame this by using 6mm cage nuts just file the hole in the frame square and clip the nuts in behind!! they work a treat!!! Quote Link to comment Share on other sites More sharing options...
jse Posted April 4, 2012 Report Share Posted April 4, 2012 I am not sure about your application but sometimes you can replace clipnuts like you show with nutplates. The plate gets pop rivited to in place and the nut portion can still move around to align with the fastener. You may find these at a local hardwae store search for them on the web. Google "Self-Locking Nut Plate, Floating" Just be real careful with the top two nuts. If they are too long, they will wear a hole in the fuel tank. Jon Quote Link to comment Share on other sites More sharing options...
trialtrial Posted April 11, 2012 Report Share Posted April 11, 2012 i overcame this by using 6mm cage nuts just file the hole in the frame square and clip the nuts in behind!! they work a treat!!! I like this idea. Those nuts are a PIA especially when doing field repairs, they knock off too easy and can fall in the muck. I was thinking of tack welding them in place, but the cage nuts sound easier... Quote Link to comment Share on other sites More sharing options...
