charliechitlins Posted March 27, 2012 Report Share Posted March 27, 2012 This is a '78 (I think) 247 and the forks seized. I got the first one apart, but it wasn't easy, and some stuff dropped out...like a rubber seal and a snap ring! Maybe if I'm really careful, I can get the other one apart and be sure how to put them both back together. Also...I know that there are some aluminum bits that bind. Could someone tell me what needs to be done to get these working smoothly? And if someone could lead me to a parts diagram... Thanks! Quote Link to comment Share on other sites More sharing options...
greeves Posted March 27, 2012 Report Share Posted March 27, 2012 Find your model here, clean it inside specially the hidraulics (use a good cleaner here), put new seals and it the bars are not bent it will work smoothly. Maybe you can try with different preloads and oils density untill you find the ones you like more, but first try the originals: Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted March 27, 2012 Author Report Share Posted March 27, 2012 Nice! Thanks. Quote Link to comment Share on other sites More sharing options...
