Gas Cap Spewing Fuel
titanium
My gas cap hose is drenching the bike with fuel and making a mess of everything. Any suggestions?
remove the cap from bike , underneath you will see the yellow part that is on a spring make sure this is seated properly , poke something in [an allen key ] to try to get it seated correctly , bear in mind the spring is quite weak ,, hope this helps, if not get a new one under warranty,,
