elgringo Posted April 2, 2012 Report Share Posted April 2, 2012 Hi All Plodding along with my Bantam build, finally got a chance to put her up on her wheels and i've hit a bit of a problem with the sprocket alignment. The rear is a Bultaco wheel and there is no way of moving the sprocket closer to the hub without some serious machining so my question is can you offset the front sprocket? It is a D7 engine and whilist i haven't managed to measure the difference accurately yet i estimate it is about 5-6mm too far in. The other option is to move the engine over in the frame but the exhaust is already virtually touching the frame down tube. Many thanks in advance Chris Quote Link to comment Share on other sites More sharing options...
andy m Posted April 2, 2012 Report Share Posted April 2, 2012 The engine needs to go over in the frame, they are one sided before you start. Also the swing arm needs widening or scalloping out the one side to allow for a trials tyre. Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted April 2, 2012 Report Share Posted April 2, 2012 Thats probably why most Bantams use either a Bantam or Cub hub or a billet copy ? Quote Link to comment Share on other sites More sharing options...
totalshell Posted April 3, 2012 Report Share Posted April 3, 2012 rex caunt has an off set 6mm engine mount on his ebay site rexcauntracing http://stores.ebay.co.uk/Rex-Caunt-Racing_W0QQsspagenameZMEQ3aFQ3aSTQQtZkm Quote Link to comment Share on other sites More sharing options...
