lee99780 Posted April 4, 2012 Report Share Posted April 4, 2012 Hi all, again, Ive read loads of posts about this already but still no idea, I'm wanting to change my oil on my06 txt pro 125, the user manual says atf, so I would of thought that, then I read other peoples posts and not too sure, the oil I can see in the level glass isn't red but not sure what it is, any ideas guys? Quote Link to comment Share on other sites More sharing options...
bmseven Posted April 4, 2012 Report Share Posted April 4, 2012 ATF Dextron III Quote Link to comment Share on other sites More sharing options...
7 Posted April 4, 2012 Report Share Posted April 4, 2012 putoline light gear oil i think will be in your bike,but atf dextron 3 is better oil for gas gas gear box 400ml only,you can buy this from millers oils brighouse in bulk 5lts Quote Link to comment Share on other sites More sharing options...
lee99780 Posted April 4, 2012 Author Report Share Posted April 4, 2012 I can get that no problem but does it matter that I'm putting different oil back in as I heard it could make the clutch plates swell? Quote Link to comment Share on other sites More sharing options...
jse Posted April 4, 2012 Report Share Posted April 4, 2012 I can get that no problem but does it matter that I'm putting different oil back in as I heard it could make the clutch plates swell? It's the type of oil that matters, not the changing. Type-F ATF seems to work better in the 06' Jon Quote Link to comment Share on other sites More sharing options...
sparky Posted April 5, 2012 Report Share Posted April 5, 2012 hi is this the best for the 2010 pro as well? Quote Link to comment Share on other sites More sharing options...
7 Posted April 5, 2012 Report Share Posted April 5, 2012 yes its spot on for all gas gas pros Quote Link to comment Share on other sites More sharing options...
faktree Posted April 5, 2012 Report Share Posted April 5, 2012 yes its spot on for all gas gas pros Apart from if its got an aftermarket DP clutch pack in it..... it will make those plates swell after time and your lever will go stiff... Quote Link to comment Share on other sites More sharing options...
