martin 305 Posted April 5, 2012 Report Share Posted April 5, 2012 Hi just got a rev 4 longride kit and the instructions are in german !! has anyone got a copy of the english ones they could e mail me ?? All fitted but dont want to fill up tank untill i am sure its all fitted ok Many thanks Martin Quote Link to comment Share on other sites More sharing options...
pindie Posted April 5, 2012 Report Share Posted April 5, 2012 Once you have it bolted the right way the only thing left is the T piece in the fuel pipe? Check for tightness and no leaks and bang her up and ride!!!!!!!!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
mb4807 Posted April 7, 2012 Report Share Posted April 7, 2012 (edited) I just got one too for my Rev 3. Just fitting it now in fact. There are no instructions on using it though. I assume you have to fill both tanks when you fill up and that the fuel gets used from both at an even rate until you reach reserve on the original tank and at that point the longride tank is dry and you switch to reserve on the main fuel tap and have what's left in the main tank? Edited April 7, 2012 by mb4807 Quote Link to comment Share on other sites More sharing options...
trialtrial Posted April 8, 2012 Report Share Posted April 8, 2012 Sorry cant find my instructions. From what I remember: Mounting the tank - remove the upper shock bolt and replace with supplied bolt (has a threaded hole in the head) - remove opposite side bolt and replace with supplied bolt (same as shock bolt) - loosely attach the fuel tank bracket to the tank - loosely attach the angle brackets to the tank - unscrew the gas cap and mount the tank - adjust the bolt so it fits as best as possible, then tighten all the bolts. Fuel Line - you will have to cut the fuel line and splice in a "T" - what did with mine was to review some mesh from the fender, and have some line poking out above the bike, I then put in a single splice to connect to the aux tank - this way I could remove it for competitions. - you might have to shorten the aux tank line or it will get kinked and you wont get flow. Usage - I have the aux tank OFF, until I drain the main tank. That way I know how much fuel I have gone through. Hope this helps. Quote Link to comment Share on other sites More sharing options...
trialtrial Posted April 10, 2012 Report Share Posted April 10, 2012 I found the instructions. PM me with your email and I will send them to you. Quote Link to comment Share on other sites More sharing options...
trialholic Posted April 11, 2012 Report Share Posted April 11, 2012 I just ordered one for a beta evo 4T and reading this post I wonder if you need to release the aux for air filter maintenance, and if so, how long does it take, is it a tedious task? Quote Link to comment Share on other sites More sharing options...
trialtrial Posted April 12, 2012 Report Share Posted April 12, 2012 Yes you need to pull the tank for filter maintenance. I pull mine on/off all the time. Undo the gas cap, undo two bolts, then disconnect the fuel line. NOTE: I put a barbed junction in the fuel line between the aux tank and the plastics on the bike. This makes it much easier to take the tank off. If you want to remove the tank and then use the bike "au naturel" (e.g. a competition) you will have to plug the fitting. Quote Link to comment Share on other sites More sharing options...
trialtrial Posted April 12, 2012 Report Share Posted April 12, 2012 (edited) I put up a blog post on the tank/seat, including pictures of the fuel line and the installation instructions. http://cameronsoftwa...ong-range-tank/ Edited April 12, 2012 by TrialTrial Quote Link to comment Share on other sites More sharing options...
martin 305 Posted April 12, 2012 Author Report Share Posted April 12, 2012 I put up a blog post on the tank/seat, including pictures of the fuel line and the installation instructions. http://cameronsoftwa...ong-range-tank/ Thanks very much for this !!Fitted it fine just was`nt sure about fuel line , Went up to a 11 tooth front cog on my 4t thanks again Quote Link to comment Share on other sites More sharing options...
mb4807 Posted April 13, 2012 Report Share Posted April 13, 2012 I've fitted and used mine now, and I'm impressed! - Barely notice it is there when doing trials type stuff, but the added fuel and ability to sit down for short sections of trail is awesome! - I just ran the aux tank until empty, with the main tank off, then when I ran the aux dry I swapped to the main tank. Quote Link to comment Share on other sites More sharing options...
portman Posted April 13, 2012 Report Share Posted April 13, 2012 (edited) I've fitted and used mine now, and I'm impressed! - Barely notice it is there when doing trials type stuff, but the added fuel and ability to sit down for short sections of trail is awesome! - I just ran the aux tank until empty, with the main tank off, then when I ran the aux dry I swapped to the main tank. How do you turn the main tank off mb? I haven't bought an aux tank (yet!) but the main tank (2012 Evo 4T) has an electric tap which has a manual "on" position plus, confusingly, an "off" setting but which only means that the tap is off IF the engine isn't running, otherwise, when the engine is running, the tap is energised and the fuel flows. As an aside I find it a nuisance there is no reserve setting on the main tank tap. Edited April 13, 2012 by Portman Quote Link to comment Share on other sites More sharing options...
mb4807 Posted April 13, 2012 Report Share Posted April 13, 2012 How do you turn the main tank off mb? I haven't bought an aux tank (yet!) but the main tank (2012 Evo 4T) has an electric tap which has a manual "on" position plus, confusingly, an "off" setting but which only means that the tap is off IF the engine isn't running, otherwise, when the engine is running, the tap is energised and the fuel flows. As an aside I find it a nuisance there is no reserve setting on the main tank tap. I've got a Rev 3 2 stroke and that's got a good ol' fashioned fuel tap with off/on/res. Fiddly to get to though! And the aux tank has it's own fuel tap too, which is on or off. Quote Link to comment Share on other sites More sharing options...
trialholic Posted April 13, 2012 Report Share Posted April 13, 2012 (edited) How do you turn the main tank off mb? I haven't bought an aux tank (yet!) but the main tank (2012 Evo 4T) has an electric tap which has a manual "on" position plus, confusingly, an "off" setting but which only means that the tap is off IF the engine isn't running, otherwise, when the engine is running, the tap is energised and the fuel flows. As an aside I find it a nuisance there is no reserve setting on the main tank tap. Maybe is possible to install and aftermarket fuel tap in the line between the main an the T fitting so you can choose wich fuel line you want to use, the one that comes from the Aux (wich has its own tap) the one that comes from the main (with the aftermarket tap) or both. Are you sure that the evo 4t doesn,t have any tap for manually close the gasoline to the carb? I'm still waiting mine.. Edited April 13, 2012 by trialholic Quote Link to comment Share on other sites More sharing options...
portman Posted April 13, 2012 Report Share Posted April 13, 2012 Maybe is possible to install and aftermarket fuel tap in the line between the main an the T fitting so you can choose wich fuel line you want to use, the one that comes from the Aux (wich has its own tap) the one that comes from the main (with the aftermarket tap) or both. Are you sure that the evo 4t doesn,t have any tap for manually close the gasoline to the carb? I'm still waiting mine.. Hi trialholic. Since the electric tap "closes" when the engine stops I suspect Beta felt there was no need to also fit a manual closing system. mb, I've just re-read the thread and realised you guys have Revs so you're lucky, you've got a "proper" tap. Quote Link to comment Share on other sites More sharing options...
trialtrial Posted April 13, 2012 Report Share Posted April 13, 2012 The Beta DOES have a reserve setting (at least my 08 4T does with the electric fuel tap). When the main tank electric tap is switched to OFF (which lets fuel flow only when the engine is running), it will drain the tank to the reserve level. To access the reserve gasoline you have to flip the little lever all the way up to the manual on setting. When the engine is off and the fuel is in the off, no fuel flows so you shouldn't need to install another valve. Quote Link to comment Share on other sites More sharing options...
