wright4d Posted April 8, 2012 Report Share Posted April 8, 2012 (edited) Can anyone recommend a good dealer within an hour or so of Cheshire who can set up my Evo 4T can't get it to run quite right after fitting Bosi exhaust tried all the suggestions regarding lowering th carb needle to richen it up etc. but still got very slight flat spot. Cheers Edited April 8, 2012 by Wright4D Quote Link to comment Share on other sites More sharing options...
nzralphy Posted April 8, 2012 Report Share Posted April 8, 2012 sorry can't help with a dealer But....... you've moved the needle the wrong way. Raise the needle to richen the midrange. Put the clip on the bottom notch, and see how it runs. Ralphy Quote Link to comment Share on other sites More sharing options...
benzman113 Posted April 9, 2012 Report Share Posted April 9, 2012 Thats true wrong way also for best performance check your tappets they will probably never been done, i did mine it starts first kick in sted of second & gave it smother running not a diffacult job to do http://www.americanbeta.com/node/708 Quote Link to comment Share on other sites More sharing options...
wright4d Posted April 9, 2012 Author Report Share Posted April 9, 2012 Sory meant to say lowered the clip and raised the needle. Just typed in a hurry, the tappits thing is another reason I need a good dealer to service it and try to get the set up right for me. thanks for th replys Quote Link to comment Share on other sites More sharing options...
