Gas Gas Clutch Spring Guide
7
hi all needing help i have put new clutch o rings the ones that go on the inside of clutch cover
pulled top hat off and spring and plastic guide shot off,what i need to know is the plastic spring guide goes in side the spring
then does the plastic bit go into the top hat or the inside of the clutch post gas gas 250cc 2010
